Re: Farmall b clutch issue
Posted by mkirsch on December 01, 2011 at 12:16:56 from (64.80.110.74):
In Reply to: Farmall b clutch issue posted by joe klein on November 30, 2011 at 09:56:08:
If it was literally okay yesterday, and not okay today, then it's more than just a clutch disk rusted to the flywheel...
It takes more than overnight to rust up a clutch.
Your pressure plate gave out. Minimally you need to replace the pressure plate, which requires splitting the tractor at the bell housing.
You'd be money ahead selling it as-is, but I don't know about an auction with it in that condition. Someone will inevitably try to drive it. Either they'll start it in gear and run someone over, or they will grind the gears off to a nub trying to shift it.
