Posted by Jason the Red on December 01, 2011 at 15:47:41 from (99.109.191.201):
In Reply to: Re: Hey Wardner posted by Janicholson on November 30, 2011 at 20:47:50:
The tractor does run and operate, however I am preparing to replace an axle seal and rear axle housing gasket. I figured since I was tearing the tractor down anyway, what was one more part to remove.
I did some more looking this evening, and I've got the numbers you wanted Jim. The large gear that mates with the belt pulley gear is 5.375 inches in diameter (from tip of tooth to tip of tooth)and contains 35 teeth. The gear opposite that one measures 2.5 inches in diameter and has 16 teeth. The next gear in sequence is 3 inches in diameter, and has 19 teeth. Finally the last gear in sequence, and the gear that drives the trans. 5th gear, is 2.25 inches and has 14 teeth.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
