Re: Gas Start Diesel Heads
Posted by bobs old iron on December 01, 2011 at 18:24:55 from (75.171.161.136):
In Reply to: Gas Start Diesel Heads posted by Dan MD on December 01, 2011 at 18:08:21:
had a gas/start diesel short period of time, i let it warm up on gas side, so when changing over to diesel, it wouldn't hit hard, made a smooth change over. as for the fast rev when changing over, my did it also for the diesel to ignite better..a heater couldn't hurt, saves on gas...i sure others have more experience with that engine...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
