Re: Gas Start Diesel Heads
Posted by D Slater on December 02, 2011 at 05:46:46 from (184.15.30.71):
In Reply to: Gas Start Diesel Heads posted by Dan MD on December 01, 2011 at 18:08:21:
Casting tech used on the heads wasn't good enough for the design. There was several head changes on some of the head numbers trying for better sevice. Some heads had 7 or more changes for the same head #. For some reason some heads lasted, so if you have one not cracked thats saw a lot of use there's a good chance its a better casting or took care of. Back in the day a local construction dealer would get new machines with cracked heads when unloading or before leaving the lot.
Lot of good ways posted to help the heads last. Make sure there's gas and a good starting system to restart tractor if engine is killed when hot. Don't overload and keep the cooling system in top shape.
