Re: Hey Wardner
Posted by Jason the Red on December 02, 2011 at 08:20:55 from (74.82.64.32):
In Reply to: Re: Hey Wardner posted by Owen Aaland on December 01, 2011 at 20:46:32:
It is on an H Owen. You went a little above my pay grade with your calculations, however if you are correct in guessing 20-25 percent reduction in gear speed, that would put fifth gear at about 12mph. Fifth gear is the only gear effected as to use this attachment the tractor"s transmission is left in neutral. Once the attachment is engaged, it transfers power from the belt pulley gear to fifth gear.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
