Posted by 400D Guy on December 02, 2011 at 10:42:23 from (69.76.146.214):
I kind of blew it and removed the distributor and hydraulic pump on my 400D without checking for timing. Read a bunch of posts and my manuals and learned that I can get it timed properly by putting the #1 piston at TDC with timing pointer on the crank pulley pointing to the mark. Now the problem:
The manual says the back of the cam gear is beveled to aid in proper insertion of the hydraulic pump gear -- need to line up the centerpunch on the hydraulic pump gear with the beveled gear. However, the cam gear is beveled on two consecutive teeth, but the hydraulic pump gear is centerpunched between two teeth. Which of the two beveled cam gears am I to place the centerpunched slot?
I noticed the crankshaft pulley is marked with an "M", then a line, then a "DC", then a line. Has that got anything to do with it, and what does the "M" mean?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
