Re: H rim width
Posted by IAtractorKid on December 02, 2011 at 19:01:04 from (208.126.16.214):
In Reply to: H rim width posted by tntleake on December 02, 2011 at 17:27:32:
12.4"s would be "correct" for 11" rims but they are also about the most expensive size you could pick. 11.2"s or even 13.6"s would be cheaper though! I like to have my letter series set up as follows:
H - 5.00-16 fronts and 11.2x38 rear
SH - 5.50-16 fronts and 12.4x38 rears
M - 6.00-16 fronts and 13.6x38 rears
SM - 6.50-16 fronts and 14.9x38 rears
