farmallman2013 said: (quoted from post at 20:17:18 12/02/11) ok so today i went outside and it was about 30 dagrees, and so i went 2 put the antifreez in my f-20... well i put it in, and went in 4 dinner..... came back an hour later and turned it over and antifreez came out the exaust pipe..... i think the block is cracked, and id like some advice at how to get to it and if i can get another block, and what it will cost.... thanks...
Farmallman2013
If the block is cracked, they crack the water jacket behind the carb.
If you got antifreeze in a cylinder its either the head or head gasket. The heads are rather robust and rarely break as the block blows out first. A cylinder full of water could break a sleeve but it would have to be much colder than 30 to do that. Not sure you could ever break a sleeve by freezing the block.
This post was edited by 36F30 at 19:37:25 12/02/11.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
