Re: 1936 farmall F-20 crack in block
Posted by 38F-20 on December 02, 2011 at 19:51:36 from (134.161.73.203):
In Reply to: 1936 farmall F-20 crack in block posted by farmallman2013 on December 02, 2011 at 19:17:18:
I doubt the block is cracked by your explanation. Heads and sleeves usually don't crack and leak either. My F-20 had a 5 inch crack (similar to the above picture, only on a F-20) in the block, but mine didn't leak into the combustion chamber. I would think maybe the head gasket started seeping. If it didn't leak before, it may just be a "tear into it" situation. Someone else may have a better diagnosis.
This post was edited by 38F-20 at 19:54:57 12/02/11.
