I'm with the head gasket, head crowd. If you don't see an obvious issue with the gasket look the head over good, especially up in the ports. I have seen them get very thin and either crack or just rust through into the port. You might just see tiny hole or maybe small water trail, poke around with a screwdriver a bit and you will go right through like a rotten egg shell. I had one do this a couple years ago, got a small puff when it started, maybe just a smell. If it sat a long time a bigger cloud. Then one day plowing it cut loose like a mosquito fogger. Pulled the head and all looked well until I saw a crack in the exhaust port, poke my finger right through it. I guess 70 plus years of heat and corrosion got to it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
