Re: F12 Issues
Posted by John M on December 03, 2011 at 09:33:52 from (67.231.174.220):
In Reply to: F12 Issues posted by John M on December 03, 2011 at 07:27:27:
Manifold if fine, not rusted through or stopped up. We pulled it off for inspection earlier inthe week. Remember this tractor was ran 4 months ago, and started just fine, and the carb and mag work on my 14 fine. Im jst baffled as to why 2 plugs get wet, 2 dont, pull the plugs, ground them out and all 4 fire. They are new, and they also run fine in my tractor. Only thing I havent tried yet is changing out the cap and brushes with mine, that could explain the 2 being wet, but I would think it would at least try to fire, but it wont. Also firing order is correct. Again, this tractor was running.
