Posted by Machine249 on December 03, 2011 at 10:53:38 from (76.100.246.141):
Just a follow up to a previous post, in which I asked if a C123 engine from a Farmall 240 would fit into a Farmall A. It does, as most replies suggested. There was some concern about the cooling system taking some imagination to make work. The C123 that I got, turned out to have water outlets for both the water pump and the thermo-siphon system. All I had to do was remove the plate on the lower outlet and install the original outlet pipe and install a plate over the hole for the water pump. Thanks to everyone that replied to the previous post. Maybe I'll continue to post follow ups as the A comes together. Thanks again. Justin
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
