Re: Engine seize question
Posted by Tom Fleming on December 03, 2011 at 14:48:14 from (206.193.250.146):
In Reply to: Engine seize question posted by BigTone on December 03, 2011 at 14:20:15:
fan blade will turn whether the engine is seized or not. However, the technique you refer too is as was just posted. On a loose engine, you can push on the fan belt to give a little more tension, then turn the fan blade. It will usually turn the crank.
The important thing is, does the crank turn over. Fan means nothing.
