Re: M has me stumped
Posted by JT on December 03, 2011 at 15:08:51 from (68.53.181.110):
In Reply to: M has me stumped posted by oldiron29 on December 03, 2011 at 14:56:51:
If you think you might have it flooded, then probably the best thing to do is to hook a chain to it and pull it and see if that gets her to fire for you....Sounds as though you have got all the bases covered for diagnostics.
