Re: Is this engine block salvageable?
Posted by rustyfarmall on December 03, 2011 at 16:28:00 from (216.248.71.224):
In Reply to: Is this engine block salvageable? posted by soundguy on December 03, 2011 at 16:21:49:
The pistons are junk. Get them out any way you can and then save the connecting rods. A good machine shop should be able to polish up that crankshaft. Don't try it yourself. Enough penetrating oil in the correct places will eventually free up the camshaft so you can remove it, but it also will be junk. Be very careful when peeling out those sleeves. It is very easy to break out part of the actual cylinder wall.
