Posted by Allen A. on December 03, 2011 at 19:25:21 from (68.151.99.237):
In Reply to: M has me stumped posted by oldiron29 on December 03, 2011 at 14:56:51:
Is it possible that you have a partially plugged exhaust manifold that is giving you the indication of compression on what is actually the number 1 exhaust stroke. take the second half of the firing order and write it under the first half. the numbers that are above and below each other are running mates, that is to say that those 2 pistons will always be in the exact same position in their cylinders. they will however be on opposite strokes. number 1 will be coming up on compression while it"s running mate, will be coming up on exhaust. number 1 will reach TDC ignition and start down on power as it"s running mate finishes exhaust and starts down on intake. remove the valve cover and watch the rocker activity. when running mate to number 1 is closing its exhaust and opening its intake ( due to valve overlap the intake will start to open before the exhaust finishes closing) number 1 will reach TDC compression. this is the most certain way to verify TDC compression number 1. check that the mag impulse is working and recheck the timing. if she flashes up watch the exhaust. maybe a mouse nest or something will come flying out. this method of verify number 1 TDC compression works on any 4 stroke with even number of cylinders. you just need to know the firing order.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
