Re: 1936 farmall F-20 crack in block
Posted by Ron Weber on December 03, 2011 at 19:26:56 from (208.54.35.235):
In Reply to: 1936 farmall F-20 crack in block posted by farmallman2013 on December 02, 2011 at 19:17:18:
Check the head bolts...if you run it in the summer, and it's 30degrees now, they could be loose.
Also, note: The f12, regular, f20, f30, 10-20, 15-30, etc pre-1939 do not have water pumps. So if you add anti-freeze, you need to pre mix it and the run the tractor for about an hour to get it plenty hot so that the thermal siphon can mix it good.
