Re: Engine seize question
Posted by JRSutton on December 04, 2011 at 04:22:09 from (75.130.109.233):
In Reply to: Engine seize question posted by BigTone on December 03, 2011 at 14:20:15:
Turning the fan blade just gives you some extra torque to turn the main crank pulley.
But - it's not foolproof.
If turning the fan does turn the main crank pulley, then the engine is free.
If you either can't turn the fan, or the fan turns and slips without turning the crank pulley - then it does't PROVE the engine is stuck. But it does mean you have to check further.
Putting it in gear and pushing with the back wheel is an easy check if it's an option.
Obviously, be 1000% sure the engine can't start before doing either test!!!!
