Posted by Janicholson on December 04, 2011 at 07:48:35 from (96.24.99.126):
In Reply to: TA questions posted by riverbend on December 04, 2011 at 07:33:03:
It requires a double split to access the rear ramp and roller clutch and seals. The parts are heavy and you will need an overhead crane or cherry picker. Kevin Meier (who frequents here) and others sell Parts and rebuilds. The only one that has seen poor reviews here is called Mechanical Diode. Hi Capacity seems like a good choice. There is a video from this site that some use along with the repair manual. They are way easier than a auto trans. I would remove it and inspect the gears internally. Tooth wear, bearings on the shafts and thrust washers. If it is sound, I would just put in the wear parts, A new ramp and roller clutch, a new TA direct drive disk and possibly the Direct drive pressure plate. THe TA throwout bearing is a must replace item along with the seals to keep the Hytran inside. Using it is the key to success. It needs to be changed from direct to TA as though the handle was almost too hot to touch. (jerk it back into TA) and released into direct the same way, as rapidly as possible) This allows the TA clutch to be used like a switch. It is never feathered into place. You will love it. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
