Re: Is this engine block salvageable?
Posted by RedRoundhead on December 04, 2011 at 09:39:24 from (108.120.24.230):
In Reply to: Is this engine block salvageable? posted by Zachary Hoyt on December 03, 2011 at 16:21:49:
I would pull everything out, and I mean everything, and get the block dipped (cleaned). It will be bare, and then you can put new stuff in. And check for cracks!
If there are parts that will not come out, then a UF bath someitmes helps loosen things. Sometimes not.
I have used ultrasonic cleaning for some rusty parts in the past. Some times you can save them, sometimes not. A heated UF bath will discolor the parts, usually.
Just my opinion. You certainly have some work ahead of you! How does the rear end look? Pull a cover off that too, to see if it is in similar shape!
Best of luck!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
