Re: Super A Engines
Posted by El Toro on December 04, 2011 at 11:05:16 from (108.3.225.57):
In Reply to: Super A Engines posted by Elm on December 03, 2011 at 15:33:48:
Jim's advice on the sleeve dimensions on the Super A blocks is very important. The early Super A's probably used a sleeve that measured 6-7/8" long and the diameter of the sleeve at the seal measured 3-5/16". The later Super A's and the Super C's had sleeves that measured 7-1/32" in length and the sleeve diameter was 3-7/16" at the seal. Hal
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
