Farmall c wide front fatory push blade
Posted by 330 Standard on December 05, 2011 at 07:32:31 from (12.22.180.2):
I found what appears to be a farmall C with a wide front and a factory push blade assembly. Owner says it is a rare blade/setup. Wide front has 2 rubber bumpers that blade lift arms sit down on. All appears factory and nothing is cobbled up or appears homemade. Any ideas or thoughts as to if this is a rare setup and its worth? Tractor is stuck in gear and motor is disassembled so i do not want to pay too much. Thanks
