Re: M is running again
Posted by gene bender on December 05, 2011 at 17:52:20 from (207.177.56.222):
In Reply to: M is running again posted by oldiron29 on December 05, 2011 at 14:50:00:
That can happen easy if you take the cover off the gears. When ever i get a new to me mag i put it in the vise and turn the mag over to see if the rotor lines up on the tower. When i get it corrected i will fasten up all four wires to plugs still in the vise then i have a gear thats missing teeth with the weights off. Chuck into my batt drill and then i can see fire to all plugs. I it fires in the vise it sure will when its in the tractor.Just take the valve cover off to make sure both are closed on#1 set the mag with pointer at the tower and install works every time.
