Re: Help! - How do you remove a carb?
Posted by mkirsch on December 06, 2011 at 05:29:17 from (64.80.110.74):
In Reply to: Help! - How do you remove a carb? posted by Tim in New York on December 05, 2011 at 16:27:39:
Look real carefully and see what is going on.
If the stud is turning, it should be threading out of the intake manifold.
The nut may be stripped and is spinning on the stud. If that is the case you need to split the nut somehow.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
