Re: farmall cub governor
Posted by screwstick on December 06, 2011 at 10:14:00 from (174.24.3.128):
In Reply to: farmall cub governor posted by blaineranger on December 06, 2011 at 09:44:18:
The lever on the governor has a spring that connects to a linkage that controls the carb throttle butterfly. Check the spring I bet it's broken.
