Re: zenith carburetor pictures
Posted by rhtx55 on December 06, 2011 at 17:16:33 from (207.119.53.101):
In Reply to: zenith carburetor pictures posted by flopguns on December 06, 2011 at 13:38:08:
if it's popping every few seconds, I can share two things that have worked for me.
1. Drain the fuel tank, when it stops draining, place a catch basin under the sediment bowl, and remove it from the tank.
A lot of water / fuel will come out, so be ready. Clean as much residue as possible (safely) and refill with fresh gas.
Condensation will build up to the point to where it will come over the top of the stand pipe on the sediment bowl, and water in the fuel will cause a miss.
2. open the main jet on your carb 1/2 turn at a time, rev the engine from idle to max a few times, and see if the miss clears, keep track of how many 1/2 turns it takes. This will be your max setting for working the tractor.
Turn back in 1/2 to 2 turns for light duty, this is your "light setting".
