Re: Adding auxillary hyd tank to 350
Posted by rustyfarmall on December 07, 2011 at 10:32:01 from (216.248.71.224):
In Reply to: Adding auxillary hyd tank to 350 posted by The tractor vet on December 07, 2011 at 09:58:27:
Check the level of hydraulic oil in the resevoir when the loader is raised as high as it will currently go. If it is low, add more oil. The excess oil should flow into the other side of the loader cylinders when you let it back down.
