This will only work if the cylinder rod is of a small enough diameter to help your situation. Many loader cylinders have a heavy rod and the bearing end will not hold enough fluid to help much with the overall capacity. Raising to to the highest level and then adding and you may just push fluid out the fill cap when you let it down. I'm sure you have already filled the reservoir to capacity with the cylinders retracted, so adding another reservoir would be your only option. I'm not familiar with a 350 reservoir, but Dad had to add to a reservoir and just screwed a pipe fitting into the fill port and added about a 2 gallon reservoir off that. The added tank had a pipe fill plug with a breather hole in it.
My loader has a built in reservoir, but it also has an external pump on the tractor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
