Re: Adding auxillary hyd tank to 350
Posted by mkirsch on December 07, 2011 at 13:38:14 from (64.80.110.74):
In Reply to: Adding auxillary hyd tank to 350 posted by Delby in IA on December 07, 2011 at 09:58:27:
If the loader booms are really 2-way, they are probably dry on the top side if you just installed the loader.
Try re-filling the reservoir once and raising the boom arms the rest of the way. When you let them down the oil will push into the top sides of the cylinders.
ONLY do this if you are 100% sure that the cylinders are two-way. If the boom cylinders are only 1-way, you will end up with a mess somewhere.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
