Think maybe your use of dished in or out is different from what most call it. Anyway I think you mean the center part of the cast wheel turned until it is more to the outside. This is just my opinion but I don't think it would be as stable from tipping as a narrow front with rear wheels set wider. Also depends on weight in tires or on wheels. But if it needs to go on the trailer the only thing to do is go with it and don't depend on the wide front for much extra stability. 400 IH wide front to the M will work okay, will probably need 4 frame rail holes drilled for the rear support. Won't cut as sharp as a narrow or some aftermarket wide fronts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
