Re: Farmall M vs Farmall MD (again)
Posted by D Slater on December 07, 2011 at 16:42:13 from (184.15.30.71):
In Reply to: Farmall M vs Farmall MD (again) posted by TWheat on December 07, 2011 at 15:18:39:
Like Jim said except I will add a little more detail. Gas engine the crank gear drives the cam gear and the cam gear drives the gear on the ignition drive shaft. MD block is taller and a little wider so to keep gears small enough diameter to fit in the space. Crank gear drives a idler gear, idler gear drives the cam gear, cam gear drives the ignition drive gear. Both gas and diesel also have another gear set in the distributor unit.
