Re: Farmall 450 Ring gear
Posted by Mike1972chev on December 07, 2011 at 17:30:39 from (99.57.0.208):
In Reply to: Farmall 450 Ring gear posted by Nate V. IA on December 07, 2011 at 14:18:14:
might be a little quicker to get the old one off by just taking a cut off wheel in a die grinder and 'score' it in between the teeth (NOT all the way thru!) and then Smack it good with a sharp chisel.Will fall right apart.
Like previous post,clean the flywheel surface good before heating the new gear and dropping it on.DONT watse any time dropping the gear on and getting it FULLY seated once you get it hot!Once it cools off,it will be stuck on there for the next 50+ years! :)
