I think you may have meant to post that most are Negative ground?
In the 10SI alternator the same regulator is used in either Positive or Negative ground. When used with negative ground the regulator is grounded to the case.
When used with positive ground the regulator terminal normally grounded is instead connected to the alternator output terminal. The number two terminal is connected to the alternator case and the number one terminal is excited by making a connection to the case. As a result the Positive ground alternator is much more complicated to wire if you are not using a one wire, self exciting regulator.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
