Re: Farmall 450 Ring gear
Posted by pete 23 on December 07, 2011 at 19:35:55 from (74.32.238.142):
In Reply to: Farmall 450 Ring gear posted by Nate V. IA on December 07, 2011 at 14:18:14:
Not too hot, glowing red is 1300 degrees, way too hot. About 400 like previous poster said. Oven works good, small propane torch usually not so good unless you had a couple of them. I always have hammer and suitable flat iron handly if it does not drop all the way on right off the bat.
