Re: Farmall 450 Ring gear
Posted by Mike1972chev on December 08, 2011 at 03:28:17 from (75.149.81.173):
In Reply to: Farmall 450 Ring gear posted by Nate V. IA on December 07, 2011 at 14:18:14:
Yes,I failed to mention that.CHERRY red is incorrect.400 deg temp stick from a welding suplly house is good for less inexperienced installers.And it was really handy when me and dad BOTH had torches heating the gear evenly all the way around.
Oven is REAL good idea,(unless your shop is FAAAAR away from garage you are working in.:)
