Your "bed of coals"idea will work. I wouldnt place the gear RIGHT on the coals.Maybe place it on top of a pizza pan?Keep your flywheel and gear CLEAN and no oil or grease!! And I would use a temp stick "marked" at points all away around the gear.If you done ALOT of them,over time,you probably wouldnt need to use a temp stick.(Would get a "feel" for what was good.)But this aint usually a job one does day to day. :)
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
