Re: Farmall 450 Ring gear
Posted by rustyfarmall on December 08, 2011 at 04:45:11 from (216.248.71.224):
In Reply to: Farmall 450 Ring gear posted by Red Roundhead on December 07, 2011 at 14:18:14:
Yes, if you don't have a torch, use your wifes oven. If you clean any oil off first, it shouldn't make a mess or stink.
