Re: UT Carter Carb question for 1950 Super A
Posted by rustyfarmall on December 08, 2011 at 05:57:47 from (216.248.71.224):
In Reply to: UT Carter Carb question for 1950 Super A posted by Allan In NE on December 08, 2011 at 05:34:11:
That hole has, or at least is supposed to, A felt filtering material in it. The hole is meant to be there to allow condensation to escape rather than just pooling in the bottom of the carb. A little dripping is normal and can never be eliminated, but if gasoline is dripping from that hole on a steady basis, there is a problem with the needle and seat and/or the float. The float MAY be leaking, or it may just be improperly adjusted to the incorrect float height.
Consult your manual for the correct settings and do not guess at it.
