Re: Re: Re: 3 pt hydraulic ram problem
Posted by Wardner on September 01, 2000 at 13:29:47 from (63.23.216.54):
In Reply to: Re: Re: 3 pt hydraulic ram problem posted by Bama Binder on September 01, 2000 at 12:52:45:
Repacking your cylinder would be a good place to start. Addding a low pressure return hose at the vent would also work.
Not very difficult to repair a tie-rod cylinder. You may need special wrenches on a welded cylinder.
Post A Followup
: Re: Re: Re: Re: 3 pt hydraulic ram problem
