Re: 560 Ta swap
Posted by Heat Houser on December 08, 2011 at 12:21:16 from (69.66.35.73):
In Reply to: 560 Ta swap posted by scotty-mn on December 08, 2011 at 06:13:49:
Early 560s used a planatary PTO and later ones used the clutch type. Make sure you have the correct PTO gear set in the center section for the type you have.
What are you going to do with the TA delete shafts? I have a 560 TA delete and wouldn't mind having a spare laying around.
