Re: C264 vs C281
Posted by D Slater on December 09, 2011 at 13:59:34 from (184.15.30.71):
In Reply to: C264 vs C281 posted by CNKS on December 09, 2011 at 13:19:55:
Yes you can use the C281 kit. But a original old type fire crater piston for a SM was different than one for a 400 or 450. Because of a different head on a SM gas compared to the other 2. May not develope as much power.
But I'm in the past on the parts. They don't make all the kits anymore. If you have a standard altitude fire crater in the SM the # on it is probably 374457 and a standard one for a C281 was 3743XX. Numbers are from memory so last 2 numbers could be off and couldn't remember the last two on the other, maybe 06.
Also the old pistons are probably forged and the new ones probably won't be.
This post was edited by D Slater at 14:00:13 12/09/11.
