Re: Super A leak
Posted by T Epp on December 09, 2011 at 14:31:13 from (66.222.110.226):
In Reply to: Super A leak posted by David Lampman on December 06, 2011 at 08:42:44:
Try ProPoxy20, you can find it at a plumbing supply house like Ferguson or Noland. It's a 2part putty stick that you knead with your fingers until it turns grey then apply to a clean,dry surface.I've used it to repair leaks in boat motors,water pumps and to repair leaking weld joints.It takes 30 minutes to fully cure and can be drilled,sanded,painted,etc.I used it to repair the check valve seat in a Cub touch control also.Best part is there's no mess like JBWeld.
