Re: Magneto question
Posted by Brownie 450 on December 09, 2011 at 17:46:27 from (66.43.241.198):
In Reply to: Magneto question posted by Machine249 on December 09, 2011 at 17:27:55:
Sounds like your rotor is not "pointing at" the distributor terminal when the spark is ocurring.
Your mag has gears which time the rotor to deliver the spark to each distributor terminal at the proper time--- when each cylinder is supposed to fire. Take the dist. cap off & bring the #1 cyl. up to TDC. The rotor should be very close to where the #1 plug wire attaches on the cap. Could be close to #4 terminal if timing is half off.
If rotor is off by much, take the 2 screws off the gear cover under the rotor & set the gears into time. One tooth will have a mark or flat & there will be 2 teeth on the other gear. These need to be in register.
