Re: Reassembly Lubrication
Posted by Paul from MI on December 09, 2011 at 19:52:35 from (204.106.243.224):
In Reply to: Reassembly Lubrication posted by Jim Paterson on December 09, 2011 at 16:52:46:
Another thing to do before you start the engine is to prime the oil pump and either turn the engine over enough to build oil pressure or fill the oil galleries with a pressure system thru the gage port so that as soon as it start there is oil to everything instantly. I use an air over oil tank hooked to the gage port. when it is pressurized it forces oil into all the galleries so pressure is built instantly on starting, no waiting for a filter housing to fill.
