Posted by El Toro on December 10, 2011 at 04:08:09 from (108.3.225.57):
In Reply to: Magneto question posted by Machine249 on December 09, 2011 at 17:27:55:
Pull No1 sparkplug near the radiator and hold your thumb over the plug hole while a helper hand cranks the engine slowly until you feel pressure then drop a long plastic straw on top of the piston then you watch the straw rise while your helper slowly cranks the engine. When your straw quits rising your No1 piston should be at TDC on the compression stroke. Remove the cap from the mag and see where your rotor is pointing. If it is not pointing to your No1 plug tower you need to pull the mag and rotate the rotor so it is at the No1 plug tower and reinstall the mag. Your plug wires need to be in this firing order on the cap. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
