Re: Magneto question
Posted by LJD on December 10, 2011 at 05:59:36 from (67.142.130.17):
In Reply to: Magneto question posted by Machine249 on December 09, 2011 at 17:27:55:
I just realized you've got a mag and not battery ignition. What I stated still applies but mags have less max voltage. Usually 16,000-20,000 max.
An .025" plug gap needs 8000 volts to fire when clean - directly from the coil. If through the cap and rotor it takes 10,000-11,000 volts.
An .035" plug gap needs 11,000 volts to fire directly from the coil. If through the cap it takes 13,000-14,000 volts.
Some mags at best can only make 17,000 volts and if worn (weak magnets, bad impulse, etc.) much less.
