Re: farmall H not firing
Posted by charles on September 01, 2000 at 22:21:48 from (216.128.175.46):
In Reply to: farmall H not firing posted by jdhump on September 01, 2000 at 22:03:53:
If your sure your timing is set right then when you start it choke it alot . If that doesent work try turning the ckoke on and off when your turning it over. They are hard to get the gas back up there again. Hope this helps.
Post A Followup
: Re: Re: farmall H not firing
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
