Re: Pinhole Final Drive Leak
Posted by Janicholson on December 11, 2011 at 15:50:52 from (67.72.98.45):
In Reply to: Pinhole Final Drive Leak posted by TheDurk on December 11, 2011 at 15:20:32:
If the pan is thin (easily pushed in in spots) I
would either replace it, or cut out the bad and weld
in new. If just one small area is affected, I would
Braze it. Clean and wire brush till shiny, then
braze from the inside. This leaves little on the
outside to look bad. I use JB weld also, but not
when I have it off of the vehicle. Jim
