Re: Super C Engine Help
Posted by CNKS on December 12, 2011 at 07:00:09 from (216.144.104.128):
In Reply to: Re: Super C Engine Help posted by equeen on December 11, 2011 at 17:53:16:
With a 354898 block you can use sleeves for 3 inch diameter, 3 1/8 in or 3 1/4 inches. That is ALL unless someone has messed with the bore. The only difference in kits used in that block is the diameter of the sleeves. I do not know what CaseIH currently sells, but virtually all of the aftermarket kits have 3.25 inch diameter pistons in them. Unless someone has messed with your block that is all you need to know.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
