Re: 350 utility
Posted by rustyfarmall on December 12, 2011 at 07:32:29 from (216.248.71.224):
In Reply to: 350 utility posted by Steve-N-TN on December 12, 2011 at 07:22:37:
Tie rod ends, spindles, spindle bushings. Sounds like it is just flat worn out.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
